Forum: Old versions
Topic: Numark Mixtrack Pro soundcard drivers for VDJ 6.1
Hi there. Where can i find the drivers for Numark Mixtrack PRO for vdj 6.1? I searched the download section, controllers but i can't find anything :/ please if anyone can help write a post here ... tnxxx
geposted Thu 25 Nov 10 @ 9:14 am
You should only need drivers for your OS, not VDJ. So install the drivers on the CD that came with you Mixtrack. Otherwise you could try Numark's website.
it installs the drivers for you when you plug the USB in to the computer from the deck..
yes it does but the controller comes with virtual dj LE and in the config menu there is no sound card options.. so one channel is on my speakers and the other plays on my headphones :S i can't do any setup in that VDJ.. how can i buy it if i don't know if it works perfectly?! When i installed it on my lap top for the very first time it showed me sound setup tab in config but when i restarted the program it was gone! So, i saw that there was a "NUMARK" driver in sound setup (you know from where you can choose ASIO drivers).. SO, ALL I NEED IS THAT "NUMARK" DRIVER FOR vdj .
You can try it out before purchasing for 10 minutes at a time with full sound config options in VirtualDJ Home FREE: https://virtualdj.com/download/free.html
There should also be an option in LE to try VirtualDJ Pro for 20 days, assuming this has not already been ussed.
NOTE: After 10 minutes, Home FREE will revert back to mouse and keyboard control only until you next restart the software.
i tried that home edition .. no cotroller supported on HOME... on my LE, there are NO sound card options and no, i didnt use those 20 days ... :///
Home FREE v7 https://virtualdj.com/download/free.html does allow controllers and advanced sound configurations to be tried for the first 10 minutes as a trial of VirtualDJ Pro features. After that, the controller and advanced sound config will de-activate and control will revert back to mouse and keyboard only until you restart the software.
I have vdj pro. but its missing the mappers and drivers for the above mention "NUMARK" sound card thing. Cant find the download in the controllers section.. link?
this support staff has no idea what they are talking about..absolutely no help MY MIXTRACK PRO ISNT WORKING CAUSE VDJ PRO 7 DOESNT WORK
Please be polite in your replies.
We know exactly what we are talking about. A very common cause of controllers not working is simply because the user does not have the latest version installed and is using an out-of-date version. The user above who we replied to does not have a Pro serial number registered to their account, so may not be running the latest version.
If you already have the latest version installed and the MixTrack is not working, then there may be something else on your system that is conflicting with the MixTrack and preventing it from working.
A common cause is Logitech Webcams which have badly written drivers that interfere with and prevent other MIDI devices from working.
If you have a Logitech Webcam or have previously used one, please contact support for a solution: https://virtualdj.com/contact/ - Or search Google for: logitech webcam midi conflict
If VirtualDJ Pro itself will not work or install either with or without the MixTrack connected, then please contact support for advice: https://virtualdj.com/contact/
well i have bought the numark MIXTRACK and download the newer version off virtualdj, but when i click on virtual dj LE my MIXTRACK turns off i am wopndering y?
hello..... i have the mixtrack pro.... with vdj pro.... my computer crashed..... i got it fixed and every since then the keylock button will not work..... everything else works just fine.... so i was wondering do i need to download a new driver or what???? thanks in advance!!!
Please check your master tempo setting in CONFIG -> Performances
If this is set to Pure Scratch then you will not be able to use keylock/master tempo.
how can i setup the mixtrac pro with vdj 7 to use the mic
sorry i write an error post
