My right deck t/c will not pick up- im not sure what happened or how to fix it.. i was on v6 and it went out i upped to v7 and its still out, somehow deck 4 will read but since i havent figured out how to set up yet i couldnt get sound but 2 still didnt work. i tested/changed the needles, reset the firmware, ran rmx without tc and deck 2 played. so it has to be in the software somewhere. can i get a little help please and thank you.
geposted Sat 27 Nov 10 @ 6:02 pm
bummpp
geposted Sun 28 Nov 10 @ 9:35 pm
Did you select the correct time codes from the pulldown menu?
geposted Sun 28 Nov 10 @ 11:26 pm
@Mistah P, the other night I kinda had the same thing happen. Deck 2's pitch started gettin all weird on me. It was like the turntable couldnt control it..............I control 4 decks with 2 timecodes. Well anyways when I switched to deck 4 it didnt happen nor was it a problem with deck 1 or 3. The next day I set everything up and started messing around to see if I could figure out what was going on. Well I flipped the record switched it to side B (using Red Serato Timecodes) and everything was perfect again..............Weird.
Now I know you said you had no sound but I couldnt control the pitch on deck 2 and thats the same deck you had problems with. I dont know what or where this is going now, lmao!!
I guess try flipping the timecode...........
Huey
Huey
geposted Mon 29 Nov 10 @ 12:00 am
Huey-
yeah in my original trouble shooting i switched the side b an still couldnt get a sound...it originally started on v6 so when i changed to v7 same issue.
@santd: what do you mean correct time codes- nothing was changed my time code selection has alway been serato v2
geposted Mon 29 Nov 10 @ 8:06 am
I seriously need help!, i even opened a ticekt 11/30 so no one else is having/or had this problem..
geposted Fri 03 Dec 10 @ 7:39 am
The same thing happened to me, right side as well. I using Traktor TCV and as soon as I pit the serato Vinyl on control came back. What TCV are you using? Try flipping the record on to the other side as huey suggested. I use side B anyways.
geposted Fri 03 Dec 10 @ 2:52 pm
i have tried running on side b..what i will try since you said the traktor kicked it back in..is flippin the left vinyl to the right deck and see if its actually the vinly
geposted Fri 03 Dec 10 @ 3:58 pm
