Hey guys, I'm a bit new to this whole DJ community. I've been mixing for about 3 months right now and I'm doing it everyday! I'm really getting into it :).
I was just wondering if you guys can help me choose out some mixers and tables. Like stuff to start out with! I'm only using virtualdj to mix right now so its a bit difficult for the stuff that I wanna do. I mix Hardcore and Dubstep, but I'm getting into Electro and House.
geposted Sun 28 Nov 10 @ 2:01 am
depends on you budget. Do you want a midi mixer or a regular dj mixer? Turntables can be expensive too, for the best ones, look at technic brand and for a lower budget, numark and others. It depends on your budget.
Check this website for the items that that sell and should work with VDJ perfectly. Also check www.pssl.com. Also check your local guitar center, they have stuff usually set up at their stores but usually not VDJ.
geposted Sun 28 Nov 10 @ 8:42 am
