Hi Everyone,
I like searching for BPM's.
Why you may ask search for BPM when VDJ will mix about anything together?
While having a Master is great, I find it easier to mix sometimes by finding songs around the same BPM.
This just gets me in the ballpark and helps me find songs and styles which may work better together.
Here is my problem and question:
I try to search for BPM with no real luck. While I can find 126 and 120 BPM those are the only ones I can find...
I have deleted everything but BPM from the search and still no luck.
Any and all help is always welcome.
Thanks
My keyword search for this thread
caddogbpm
Thanks
caddogbpm
geposted Mon 29 Nov 10 @ 11:15 am
You need to search within a range, for example 126-130
Keith
Keith
geposted Mon 29 Nov 10 @ 11:34 am
Or you could just set up a bunch of filter folders, say like 75-85, 85-95-105 and so on and so on. That's what I did then just nest them in another folder marked "BPM" or something to that effect.
Just my thoughts
Huey
Just my thoughts
Huey
geposted Mon 29 Nov 10 @ 12:04 pm
Keith
Keith
Thanks Keith,
That was simple and it works...
I'm at home with the range where the tunes and music rocks... hahaha
Really, thanks I needed that...:)
geposted Mon 29 Nov 10 @ 6:46 pm
