I purchased deejay trim and I use it with virtual dj. I cannot scratch because it has a delay and makes a funny noise. It seems as if(for example) the turntable is dragging the song behind as oppose to it being right on top of it. I can cue up songs but it delays also. When I press cue the song does not play right away it makes a distortion noise then plays.
geposted Mon 29 Nov 10 @ 4:18 pm
Did you take the time to read the Timecode configuration guide:
https://virtualdj.com/wiki/TimeCode%20Config.html
You may also want to optimize your system and disable some applications that can potentially create problems and delays, as explained in this document:
http://ts.hercules.com/faqs/eng/her_eng_00364.pdf
geposted Tue 30 Nov 10 @ 2:30 pm
DJ Trim works fine for me running timecodes altough I do need to select vdj timecode cd old version but am not sure if this is anything to do with the trim
geposted Tue 30 Nov 10 @ 3:40 pm
