Hi,
I have the same problem in the software directly, as with controllers.
The normal que button reacts very fast when pressed.
But the extra que buttons (3 in the default skin, and on my dns-3700) react not that fast.
It is as if it only allows to be fired after a full beat or so.....?????
In other words you cannot fire the extra ques as fast as the normal que.
This makes beat creation with the software impossible!
Is this a bug?
Can it be fixed?
SalsaJay
Early adopter of VDJ
Is this a bug?
Can it be fixed?
SalsaJay
geposted Tue 30 Nov 10 @ 6:16 am
It's not a bug, it's a setting on your end. Hell, you can drum a hot cue.
Turn off smart_cue - on a default skin it's the padlock next to the words "HOT CUE".
geposted Tue 30 Nov 10 @ 6:51 am
Hi Scott,
Thanks for this help ;)
But next time I read the manual better.
(I mostly never do I must admit....)
Greetings from Holland,
Jay Kersten
Jay Kersten
geposted Wed 01 Dec 10 @ 7:41 am
