Hey, I've had a dj control steel for a few months now and its had this issue for awhile but it only happens every so often. when i'm using it sometimes the lights will start going crazy and knobs in buttons will start going off in the program on my comp. It never used to bother me to much cause it did not always happen but if i'm going to be djing in a club i need everything to be working smoothly. i'm pretty certain i have everything updated, unless it didn't work properly, but i'm not really sure how to check.
any help is appreciated thank you!
-spencer
-spencer
geposted Tue 30 Nov 10 @ 11:46 am
i found the info
driver package: v2.22
firmware: v1.0.0.13
server: v10.40
dj api: v6.3
thanks again
firmware: v1.0.0.13
server: v10.40
dj api: v6.3
thanks again
geposted Tue 30 Nov 10 @ 11:48 am
The latest driver is version 2.45
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=61&pid=226&cid=1
Did you notice any specific circumstances when the problem seems to happen ?
geposted Tue 30 Nov 10 @ 2:33 pm
at first it seemed only when it was on my lap, so i was thinking only when it was being moved around alot. but recently its been doing it even when its still. i've installed the driver, so i'll fiddle around with it more and let you know if it acts up again. thank you!
geposted Tue 30 Nov 10 @ 5:20 pm
