I'm getting huge distortion when playing from a laptop with VDJLE
Made a vid below to show exactly whats going on. Ch2&3 are usb/pc, ch1 is line-in.
Using an HP tablet tx2604 (4gigs, dual core amd) More than enough juice.
I followed the instructions online and in the manual. Tech support was even baffled. Any help appreciated, I have a performance on Friday :S
I'm starting to think its the ASIO drivers that are culprit.
http://www.youtube.com/watch?v=ZDIaSlYHchI
geposted Tue 30 Nov 10 @ 6:12 pm
2 things I forgot, I upgraded firmware to 3.11 and it works on my tower pc, just the laptop is the issue.
geposted Tue 30 Nov 10 @ 6:14 pm
What is your OS in laptop and your Tower PC?
geposted Tue 30 Nov 10 @ 7:34 pm
Tower is win7 64
Laptop was running vista 32 bit. I just made a partition and installed the same as tower (win7 64) and still the same :@
geposted Tue 30 Nov 10 @ 8:18 pm
Then your laptop isnt able to run real time applications.
Check this,might help you
https://virtualdj.com/forums/105257/PC_Version_Technical_Support/_DPC_Latency_Checker_(__2009_THESYCON)_Helped_Me_Fix_My_Audio_Problems___.html?page=1
geposted Tue 30 Nov 10 @ 8:34 pm
As has already been answered to your identical post on the American DJ forums, it's your AMD CPU that's the issue.
You need to download and install the "AMD USB filter Driver".
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=uk&lc=en&dlc=en&softwareitem=ob-63418-1
geposted Wed 01 Dec 10 @ 12:06 pm
Yup, works fine now.
For those having the same issue, 2 things worked for me.
1. I installed Win7 64 bit (dual boot). Played with the settings and it cleared the problem.
2. Install the "AMD USB filter Driver" from mfg's website. Worked as well for my 32bit vista install.
Referenced article. http://forums.americandj.com/eve/forums/a/tpc/f/727105965/m/9100014706
geposted Wed 01 Dec 10 @ 12:53 pm
i have the same problem, but my laptop is an aspire one 150 from acer. I have windows XP for OS, where can i find the driver??
geposted Sun 19 Dec 10 @ 7:33 pm
I have a brand new HP Pavillion Laptop and Windows 7 and a 64Bit OS 6gb and on dedicated GB to the sound and graphix cards, Installed VDJ pro basic for the trial and it is skipping and popping particularly when I am loading videos into the decks and also intermitently. I have updated all drivers I cant figure this out. Any Ideas?
geposted Sun 19 Dec 10 @ 8:15 pm
I have vdj pro 7 installed on a viao vgn-nw240f and i control it with the denon hc 4500. using the denon asio sound card i have a cpu issue when a track is playing on one of the decks when i load the second deck my cpu goes very high and the sound skips and sometimes distorts.
Windows 7
Intel(R) Core(TM)2 Dou
CPU T6600 @
2.20GHz 2.20GHz
(Ram) 4.00GB(3.84 GB usable)
64-bit Operating System
Windows 7
CPU T6600 @
2.20GHz 2.20GHz
geposted Mon 20 Dec 10 @ 5:08 pm
This issue is most likely caused by performance issues with your computer and/or incorrect configuration in VirtualDJ. Please see https://virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html
It is normal for CPU usage to go high while loading a track (You want the song to load as fast as possible.) This will not have any adverse effect on the playing song unless there are performance issues with your computer (See above.)
geposted Tue 21 Dec 10 @ 5:51 am
Thank you! I changed the screen resolution I believe it was from that.
geposted Tue 21 Dec 10 @ 10:46 pm
