2 quick questions that i forgot to ask at this summers past DJ show in AC when i saw the main guys at the Virtual DJ booth. ok #1 Is there a way to delete history of a days worth of playing since i spin in Go Go and i have 7 hours worth of mixing everyday? and does this effect the speed of the program and my computer if i keep all this history and #2 i think i hit force quit on my mac and maybe lost some settings on my VDJ, I am using a Hercules Mk4 and a Mac and Virtual 7 and when i hit the SYNC button in 2 tracks with the same BPM they dont line up anymore. Just for my lazy days how do i fix this problem?
Thank you Guys
Thank you Guys
geposted Wed 01 Dec 10 @ 3:39 am
Number 1 - You can't delete history on the mac from within VDJ as it is a well reported bug that has still not been fixed, however you can do it manually by navigating to the history file and doing it from there.
Having these files does not impacy performance in any way.
Keith
Keith
geposted Wed 01 Dec 10 @ 4:37 am
What about my other question with sync button and beat mixing?
geposted Sun 05 Dec 10 @ 4:45 pm
try reverting back to factory settings on the mapper and double check to see if its still hapening, there may be a problem with your mapper or settings.
i found the other day that id done something wrong and ended up with a pitch change for my jogwheel for some reason. not sure how but i reverted back to factory and went back through and set everything again just to be sure. everything works perfect now.
you could have a good rummage through and search for a problem but in all honesty i think its far easier and less stressing just re-doing it.
also even if the bpm is the same you gotta remember sometimes the beat is out and you have to jog it a little just incase you forgot with all this new fangled technology. lol.
anyway hope this helps.
geposted Mon 03 Jan 11 @ 12:02 pm
