I have a HP Pavilion dv7-4190us 64 bit Win 7 unit that kicks booty, but it seems to forget some settings such as:
- I have to unplug, plug in Denon 3700 decks before VDJ will see them
- I have to change, then reset sound settings before it'll respond to my Denon 3700 decks.
Any ideas?
Any ideas?
geposted Wed 01 Dec 10 @ 9:52 am
are you plugging in to same usb port as the ones you used when updating drivers ect
geposted Wed 01 Dec 10 @ 1:20 pm
No drivers installed. Doesn't appear to need them, everything works great. Everything remains plugged in.
geposted Wed 01 Dec 10 @ 1:23 pm
Well Scott just made a plugin that'll help you with that, I think, lol! Go to the plugin section and look for something that will save your settings.
Huey
Huey
geposted Wed 01 Dec 10 @ 1:41 pm
Ok will do, thanks!
geposted Wed 01 Dec 10 @ 1:43 pm
ok mate.was just saying its good practice to keep same usb ports used.
geposted Wed 01 Dec 10 @ 1:53 pm
Yes I know. Thank you for the suggestion.
geposted Wed 01 Dec 10 @ 1:56 pm
