Hey guys, I'm wondering if anyone can help me out. I just purchased the Numark Mixdeck which I was told that you could use it just fine with Virtual DJ, however for some reason I only get sound from one channel. The buttons all work on the other channel but no sound. I've tried various sound setup options on the settings but none seem to work. Anyone know what I'm doing wrong?
geposted Fri 03 Dec 10 @ 6:58 pm
In an effort not to have to type the entire answer out, please do a search for mixdeck and you will find about 10 really good threads that describe the way to set this up perfectly. Also, there is a youtube video out there in case you are a visual learner like myself.
Best of luck, it's an easy setup!
Scott
Scott
geposted Fri 03 Dec 10 @ 8:38 pm
