I have tried mapping "sampler pitched" to a button on my midi controller. I have mapped it to different buttons with the same results.
everytime i press "sampler beatlock" it reverts back to match pitch. I can't get "sampler pitched" to work.
I want both to be working so i can get the pitch matched and beatlocked.
I have mapped it correctly and i can map other actions to the buttons i am trying to map "sampler pitched" to?
geposted Sat 04 Dec 10 @ 2:20 pm
sorry forget that last bit but everything else
geposted Sat 04 Dec 10 @ 10:38 pm
Bar the last post the first post was right. Does any know what may be going on here?
geposted Tue 07 Dec 10 @ 10:46 pm
The funniest thing about this is that the files are mapped correctly and everything else works bar this.
geposted Thu 09 Dec 10 @ 4:22 am
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="Trigger Finger" author="Lee Eather" description="USB Trigger Finger" version="700" date="29/11/2010">
<map value="Sampler play" action="sampler play" />
<map value="Sampler stop" action="sampler stop" />
<map value="Sampler select" action="sampler select +1" />
<map value="Sampler record" action="sampler rec" />
<map value="Sampler pitched" action="sampler pitched" />
<map value="Sampler beatlock" action="sampler beatlock" />
</mapper>
<device name="Trigger Finger" author="Lee Eather" type="MIDI" drivername="USB Trigger Finger">
<button note="0x00" name="Sampler play" deck="1" />
<button note="0x01" name="Sampler stop" deck="1" />
<button note="0x04" name="Sampler select" deck="1" />
<button note="0x05" name="Sampler record" deck="1" />
<button note="0x09" name="Sampler pitched" />
<button note="0x0A" name="Sampler beatlock" />
<button note="0x02" name="Sampler play" deck="2" />
<button note="0x03" name="Sampler stop" deck="2" />
<button note="0x06" name="Sampler select" deck="2" />
<button note="0x07" name="Sampler record" deck="2" />
</device>
This is the mapping
</mapper>
</device>
This is the mapping
geposted Thu 09 Dec 10 @ 8:41 pm
Sampler pitched is something that i had never managed to make it work. I have sent pm to a member of the Dev Team in the past, posted this also, but never got a solution.
geposted Thu 09 Dec 10 @ 8:48 pm
Doesn't 'jpboggis' do all the mapping?
He has taken care of all the mapping for me and thought he may know why it isn't working... I have it mapped to a button note with pressure sensitivity but thought that the on off messages would be all that is needed so yeah i think it is a problem with virtual DJ.
P.s. 'jpboggis' iam not saying this is you.
This is obviously something wrong with virtual DJ and why it isn't working. If i can get 'beatmatch' to work (on sampler) which is all simple on off then it must be something that isn't working.
P.p.s i would like this fixed.
Thanks.
Thanks.
geposted Fri 10 Dec 10 @ 12:49 am
