Hi,
I am thinking of getting my girlfriend a mixtrack pro, but her laptop is pretty old and i am a bit concerned it may not be compatible due to the tech requirements. All i know right now is that it is a toshiba and i think it has a celeron m processor 1.46ghz, 512 ram and runs vista or xp. Now i know the mixtrack needs certain tech requirements, will this fulfil and work ok or not in your opinion? Also, if i were to try and download the free virtual dj software from this site to see if it will work on her laptop and it does, can i assume the mixtrack and software supplied with it will also work?
Help will be really appreciated on this one!
geposted Mon 06 Dec 10 @ 8:02 am
Ok now your just being lazy...........why not google mixtrack pro and see what the system requirements are, it'd be a LOT FASTER then asking here. I don't know what that requires but you said her laptop had a celeron in it, I don't think that would even work for VDJ. So I would say by a new laptop for her first then get the other hardware later.
Huey
Huey
geposted Mon 06 Dec 10 @ 11:38 am
