Is there a way to transfer the cue points from one machine to another... I.E.
I have it set up on my pc at home, and VDJ remembers the cues points for the tunes I want to mix.
Want to be able to just move cue points to macbook for mobile use.
I have the same library on both machines.
any help is appreciated
geposted Mon 06 Dec 10 @ 5:22 pm
Cues are held in the database. If you use the tools in VDJ to copy the track to an external drive and then attach that drive to the other PC either read the track from there or use the VDJ tools again to copy the file to the local drive.
The VDJ tools I refer to are the ones you get when you right-click on a file and under the File operations sub menu.
Using the copy file option will not only copy the file to the other drive but will also copy the database info to a new or existing database on the Target drive.
Cheers,
Roy
Cheers,
Roy
geposted Tue 07 Dec 10 @ 2:31 am
