Gang -
Has someone made a sticky or compiled a list yet?
There are many more things that 7 does over XP/Vista that might cause grief - like USB audio disconnects.
What should we check/uncheck/disable?
geposted Tue 07 Dec 10 @ 12:30 pm
Try this guide it's been a must do for me every time I would format my win 7 machine. I believe there might be a option that allows you to select the power management function and behavior of the usb...somewhere in the services. Hope it helps, it's helped me and I'm on win 7 64bit.
http://www.blackviper.com/Windows_7/supertweaks.htm
geposted Wed 08 Dec 10 @ 2:49 am
