Can anyone tell me how to copy a play list from one computer to another? Or Virtual Folders?
geposted Tue 07 Dec 10 @ 5:49 pm
Your playlists are saved as "*.m3u" files.
Copy to a stick, and paste into same dir of destination machine.
(This assumes your "crate" is identical in both machines. It couldn't work if they're not).
geposted Sat 11 Dec 10 @ 1:49 pm
Hi all newby on deck.....
I am wondering how you can make a 6 hour video mix (list all songs on right hand side of VDJ & smart mix on) and then save it like a project so I can add or take away videos later? By this I mean shut down VDJ then open it later and have the mix/list appear on the right hand side like a project? (VDJ V7, Win 7 64bit, x2 HDMI video cards)
Once I have this how can you save this "mix" without recording it as I don't want to sit for 6 hours while it plays through? If the mix is saved etc as above then how....do I set VDJ to show only the output video (my video mix) on one Video card going to my projector (HDMI) & still be able to use VDJ to add video tracks as I go like a DJ?
Hope this is clear enough as I am having a party N/Years & want to be able to play video already pre loaded but if someone ask's for a video song I can drop it into my mix. Please help this is a good one I reckon and a challenge for the tech heads to solve?
geposted Tue 14 Dec 10 @ 6:43 pm
