Ok, here's the problem.
Ive just recorded a mix through Virtual dj. But it has ended up being to big a file to fit on a normal cd. is there any way i can reduce the size and still be able to play it on a normal cd player??
geposted Mon 04 Jul 05 @ 7:48 am
Actually no.. Normal cd-players usually support cdd and wav files. Both of them has the same lenght. The only way you have, is that you cut your mix with program like you get with nero or any other program.
Dj Nikki
Dj Nikki
geposted Mon 04 Jul 05 @ 4:21 pm
