Hi Guys.
Does anyone use a Lite version of Windows 7 Home Premium 64 Bit as I have a Sony Vaio Laptop which came with Windows 7 Home Premium 64 Bit but has also installed lots of Sony Vaio software. I don't want to start uninstalling anything as I do use this laptop to DJ and I don't want to start having problems.
geposted Wed 08 Dec 10 @ 11:50 am
decrapify is software that removes alot of not needed info.
geposted Wed 08 Dec 10 @ 1:42 pm
Uninstalling all the Sony crapware will significantly speed up your machine as it will remove a load of items from startup.
Once you have done that and defragmented you will notice a difference.
My son's Vaio LT2S has been for a motherboard replacement and Sony have replaced my Windows 7 OEM install with the original Vista and over the top Sony crapware. Not happy!
Keith
Keith
geposted Wed 08 Dec 10 @ 2:35 pm
uninstall the barfware !
you get problems from having it , not uninstalling it !??
then defrag
get CCleaner (it's free) and run it , it will clean your filthy caches
and appalling registry !
if you get Game Booster (also free) it will find and turn off background processes , also
giving you a more dedicated system .....
plus there are still more easy tweaks all free ....
edit
since you mentioned you don't wanna start having problems.....
i do this just about everyday.....
set a restore point yourself ....easy enough to do with windows default utility
but if you need hand holding , get QuickRestore Maker free from the Windows Club
leave it's icon on your desktop , and now you can set a restore point with one click ,
BEFORE making any changes ......
then defrag
edit
geposted Sat 11 Dec 10 @ 4:20 am
where can i find virtual dj 7 home edition please help
geposted Wed 27 Jun 18 @ 11:01 pm
V7 is no longer available to download for home users
VDJ2018 is available here.
https://virtualdj.com/download/
Yep old thread let me get my keys.
Locked
Locked
geposted Thu 28 Jun 18 @ 12:23 am
