I have 2 sounds cards here. Virtual vinyl and the SL1.
When i hook up the Virtual Vinyl every thing works fine i'm using rane Vinyl. But there is a problem. When im scratching there is a little funny sound when i let go of the record.
So i unhooked the Virtual Vinyl.
Hooked up the SL1 and guess what?
Same problem. I tried both on a Mac And PC.
Does anyone have an idea on how to fix it.
I tried to fix it in sound performance. still nothing.
I have 1200-MK2. Today i had the platter spinning but halted the record and virtual Dj went crazy. The tack that i had be for mixing started playing on its own.
geposted Wed 08 Dec 10 @ 6:57 pm
It seems that you have a timecode settings problem. Go to Sound Setup..then click on Input..Select timecode...Then click on Timecode Config...Then click on Debug...Make adjustments as you're checking the result until it's fixed. I always select the Serato timecode as input signal that works fine for me and use relative instead of smart relative.
geposted Wed 08 Dec 10 @ 8:20 pm
I have tried that still same problem.
My setting
Both/
Vinyl: Serato Vinyl CV02-A Mode: Relative
I went in to Debug
i have pitch Sensibitity set to 3.00%
Lead Time 0.0ms
I went over to the performances tab
Latency: was set to (auto) Changed to (512 (11ms))
Scratch
Optimize for Quality
Master Tempo
Pure Scratch
My setting
Both/
I went in to Debug
Lead Time 0.0ms
Scratch
Master Tempo
Pure Scratch
geposted Thu 09 Dec 10 @ 9:25 am
