i am having trouble translating the keyboard shortcuts to my Dell XPS m1330 laptop keyboard.
for example - what is?
shift +num+
i am trying to change the pitch just a hair, and my Hercules Steel doesn't do that well.
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
shift +num+
geposted Wed 08 Dec 10 @ 10:35 pm
That is SHIFT held down and then press the + (Plus) key on the numeric keypad (Most laptops do not have one of these, but usually have fn keys that can be used to emulate one.)
For fine pitch adjustments, simply map appropriate keys to the following:
pitch +0.01%
pitch -0.01%
Also, try using a smaller pitch range (E.g: 6%) for more accurate adjustments with the slider.
pitch +0.01%
pitch -0.01%
geposted Thu 09 Dec 10 @ 12:59 pm
