Hi
Simple question i hope but cant work it out for some reason...
What is the keyboard script needed to assign a keyboard key to play a certain sample only when you have the key held down?
I can assign a key (for example "spacebar") to play a sample but it plays until you tap the key again, I want it to only play when the key is held down.
Thanks
Craig
Thanks
Craig
geposted Thu 09 Dec 10 @ 1:21 pm
Here's the snippet from the WIKI...
holding : execute different actions depending if the key is pressed for a long time or not: 'holding ? automix : mix_now'. you can specify the time ('holding 1000ms'), by default it's 500ms.
See the full list of verbs here -> https://virtualdj.com/wiki/VDJscript_verbs.html
Hope this helps.
Hope this helps.
geposted Thu 09 Dec 10 @ 1:53 pm
try ..
sampler 1 play while_pressed
using holding you will have a delay, and certainely it will not stop the sampler after release.
geposted Thu 09 Dec 10 @ 4:32 pm
Follow DJDAD's advice...he's right...god knows what I was thinking...lol
geposted Fri 10 Dec 10 @ 3:21 am
Thanks Guys
I knew It would be simple but couldnt find the right script for the life of me for some reson.
Thanks
Thanks
geposted Fri 10 Dec 10 @ 8:27 am
