ok...thanks for reading...is there a way, using 'skype' mic/phones to record vocals with the RMX on VDJ...I think my first wrong move is having the mic hooked into the lappy--the mic needs to be plugged into the RMX...? I am using the standard headphone adapter to plug the headphones into the RMX---can I use this same adapter to plug the mic into the RMX or are they two different inputs and I am being ridiculous and cannot use the 'skype' mic with the RMX...?
geposted Fri 10 Dec 10 @ 7:03 pm
...I'm such an idiot...
geposted Fri 10 Dec 10 @ 8:09 pm
either connect the mic to the RMX (usb mics cannot connect to the RMX so use a mic with a
1/4 " connector)
or
use the usb mic and the default soundcard as it's sound source (primary sound driver)
the music will use the RMX 'S soundcard
in advanced config click the plus and under inputs select microphone , then use primary sound driver
or line Hercules driver , whichever works that should do it , feel free to PM me if you need more help
1/4 " connector)
or
geposted Sat 11 Dec 10 @ 4:07 am
...cool---thanks bruddah...you always have my back and i appreciate it as always!!! :) delta force for life
geposted Mon 13 Dec 10 @ 4:16 am
...thanks tearemup...for awhile i couldn't see your post...anyway--i will check out your blogs...thanks for having my back! :)
geposted Mon 13 Dec 10 @ 4:17 am
