As the title says, i i get a distortion in the bass when i choose the "Headphones" option in Output, the sound is great if i just let it be with one output...
I downloaded the home edition and i know that it does only work 10 minutes...
But i really want to get this program... if i can get it to work...
Soo, does anyone know what to do to fix it?
Im using a Sennheiser USB adapter. I know it works because my friend uses the same external soundcard on his computer...
geposted Sat 11 Dec 10 @ 7:35 pm
Some soundcards have not enough power ;-)
You use the 2 soundcard option?
Please tell me your settings in VDJ Config -> Soundcard and Perfromance
geposted Mon 13 Dec 10 @ 7:12 am
If you are using two different sound cards, make sure that they have the same audio properties set in MacOS's Audio MIDI setup (Applications > Utilities > Audio and MIDI Setup)
Set each card to the same sample and bitrate, e.g: 44100 Hz, 16-bit
geposted Mon 13 Dec 10 @ 4:49 pm
Hi i have a simular issue. When I turn up the bass all the way on the VMS4 using virtual dj pro I get bad distortion.
Im using a macbook pro running lion, and my config. is 4 decks advanced:
Deck 1 - VMS4 audio midi device - output 1&2
Deck 2 - VMS4 audio midi device - output 3&4
Deck 3 - VMS4 audio midi device - output 5&6
Deck 4 - VMS4 audio midi device - output 7&8
When I plug an ipod right into it and turn the bass all the way up it has fine bass but not when connect to VDJ!
Help?
Help?
geposted Mon 19 Dec 11 @ 8:01 pm
