if there's anyone here using the hercules rmx i need help.
i just got the pro version of virtual dj and i'm having difficulty trying to map the code for the parameter slider effect control for the jogwheel when my effects are activated, can anyone help me please...
geposted Sun 12 Dec 10 @ 12:23 pm
deck left effect active ? device_side 'left' ? deck left effect slider 1 : deck left effect slider 2 : deck right effect active ? device_side left ? deck right effect slider 1 : deck right effect slider 2 : jogwheel
This way the left jog will handle the slider 1(paramtr1) and the right jog will handle the slider 2 (paramtr 2)
geposted Sun 12 Dec 10 @ 1:22 pm
Sounding stupid has never stopped me from asking questions, so I won't start now...
what's a parameter slider?
I too have the Hercules Rmx, so, I'm interested on what that is and what's the use of it. Thanx :)
geposted Mon 13 Dec 10 @ 9:56 am
Hahaa!! Your not alone bro! Well you know when your using the Flanger and you move the knobs on the screen to vet a different sound? Well the knob your turning is the parameter slider. Some effects have 1 slider some have 5/6. By moving these you change the behavior of the effect.
Hope that makes sense
Huey
Huey
geposted Mon 13 Dec 10 @ 10:18 am
do i need to make a new key for it? thanks bro
geposted Tue 14 Dec 10 @ 9:25 pm
i tried to copy and paste the map cope you posted but it's still not doing what i want it to do, email me at casey_juco@yahoo.com
geposted Tue 14 Dec 10 @ 9:29 pm
Sorry i just realised that there was a small syntax error..
Try this
deck left effect active ? device_side 'left' ? deck left effect slider 1 : deck left effect slider 2 : deck right effect active ? device_side 'left' ? deck right effect slider 1 : deck right effect slider 2 : jogwheel
You also have to assign your controler as left-right (Config-Mappers-Mapper options)
Try this
geposted Wed 15 Dec 10 @ 5:48 am
oh yeah! I get it.
now that makes sense. I will have to try that.
geposted Wed 15 Dec 10 @ 11:56 am
i'm sorry bro i'm totally lost.... do you have aim or yahoo messenger?
geposted Wed 15 Dec 10 @ 9:17 pm
