Simple question:
When I activate effects, they can only apply to either deck 1 or 2.
How can I make the effects apply to decks 3 or 4?
Thanks
Thanks
geposted Mon 13 Dec 10 @ 10:33 pm
How do you activate the effects? Are you using keyboard or controller ? How do you control decks 3 & 4 ?
geposted Tue 14 Dec 10 @ 9:42 am
I use a TotalControl and hit the PFL buttons to switch from decks 1/3 and 2/4... I was referring to when I switch to the effects tab where there is the list of effects and I can either activate on deck 1 or 2. I can do it from the effects knob but its hard to land on the right effect with the knob when I'm in a mix.
Any idea how to do activate on other decks?
geposted Fri 17 Dec 10 @ 10:34 pm
Not possible through the effect page. Only from your controler or keyboard.
geposted Sat 18 Dec 10 @ 6:23 am
