Hi, I have just installed my Denon HD2500 to control my Vdj but some of the features doesn't work like, the Jog Wheel, the Effect won't play the correct effects I selected and the Loop has a mind of it's own, selecting in random... How can I map the Denon to get the feature to work properly? Thanks,
geposted Wed 15 Dec 10 @ 12:55 am
I own a 2500 too. I just downloaded a mapper by going to DOWNLOAD then Plugins then Controllers. I don't remember which one I got, but just look around and you'll find it. If there is something you want to change I think you can change it with the Action-learn button, but I am not 100% sure.
geposted Wed 15 Dec 10 @ 4:32 pm
