Hello,
We just released a quick maintenance update.
This version fixes the problem of slow loading videos with 48kHz audio, fixes a small crash that could happen when effects with non-standard interface were quickly changed from a knob on a low-latency device (like HID), and makes a change in the iPhone/iPad discovery that was required by Apple.
As usual, the upgrade is free for all 7.x users.
geposted Thu 16 Dec 10 @ 3:09 am
Thank you!
geposted Thu 16 Dec 10 @ 4:34 am
Thank you! I have used the registryHack ResampleFilterInterp set to zero to fix video loading problem... should I return the original default value before installing and what was the default value?
geposted Thu 16 Dec 10 @ 6:09 am
Christmas came a week early this year!! Thanks for the update and slow load fix!!!
geposted Thu 16 Dec 10 @ 6:48 am
Videos load fast ! Thanks for the update. It works fantastic !
geposted Thu 16 Dec 10 @ 7:09 am
Thanx.
geposted Thu 16 Dec 10 @ 7:23 am
Thank You :)
geposted Thu 16 Dec 10 @ 8:27 am
Version 7.0.2 will do the changes needed automatically on the first run.
No need to worry about this.
geposted Thu 16 Dec 10 @ 8:48 am
Should be noted that 7.0.2 fixes the simple midi control issues with Apple. With 7.0.0 simple midi controls could not be programed.
geposted Thu 16 Dec 10 @ 8:56 am
HA HA!! Loading 4, 10+ min vids while playing one and using muliple effects at the same time with ext video and the CPU is not peaking!!
Thanks team! 100% customer satisfaction!!!
geposted Thu 16 Dec 10 @ 9:11 am
tested with random video selection, got a nose bleed with the speed it was loading.
Cheers.
Cheers.
geposted Thu 16 Dec 10 @ 9:22 am
thank you!
geposted Thu 16 Dec 10 @ 10:30 am
Is it possible that the link to Windows Cnet download still points to 7.0 instead of 7.0.2?
I'm having problems pairing my iPad with my Windows VirtualDJ 7.0
geposted Thu 16 Dec 10 @ 11:25 am
Thnx. seemed to fix my problem
geposted Thu 16 Dec 10 @ 12:47 pm
I think CNet need some time to update their system. You should take a look again in a few hours.
Version 7.0 is not able to handle the iPod / iPad devices because of a change in the communicaton / recognizion protokoll. That's the point why Apple did not release it earlier. They want to see their 'Bonjour' Service to be used.
Greets, Heiko
geposted Thu 16 Dec 10 @ 1:02 pm
Greets, Heiko
Greets, Heiko
ok, thanks. However the Mac version is showing the new 7.02 download, I would presume that both where supplied to cnet at the samen time. Is there perhaps an alternative download location?
geposted Thu 16 Dec 10 @ 1:28 pm
+1
Videos now load lighting fast.
Very happy now (",)
geposted Thu 16 Dec 10 @ 4:16 pm
Niceeeeeee, works well A+
geposted Thu 16 Dec 10 @ 4:47 pm
100% fix thanks team its running like a dream with videos and firetext
geposted Thu 16 Dec 10 @ 5:29 pm
Thanks for the update!!!!
geposted Thu 16 Dec 10 @ 5:35 pm
