Topic: VirtualDJ iRemote for iPhone/iPad/iPod - Page: 8
yes, you need to activate vinyl mode on the host PC right deck. There is a little "V" next to the platter on the default skin.
adamlonsdale wrote :
Hey. I'm having a bit of trouble using this. I have VDJ opened with "Enabled" set to true on the iPhone tab. I load up the app on my phone and it just says "Trying to locate Virtual DJ" Any ideas? I'm guessing theres a specific port that I need to unblock
Cheers,
Adam.
You need to create an adhoc network first.
http://www.7tutorials.com/how-set-ad-hoc-wireless-computer-computer-network
Hiya,
I already have the phone and my laptop on a wireless network, I think I just need to unblock a port. Otherwise I wouldnt be able to use the internet! :)
Thanks for the reply,
Adam.
One thing I had to do was change the security settings for the adhoc network to wep from wpa2 on order to get it to work
change wireless encrytion to TKIP if it is set to AES... BTW got the same problem...but case solved
Hi,
I have set up a ad hoc wifi connection and I can see the connection on my other laptop and connect to it with my other laptop but when I try and connect my ipad to the ad hoc. it always says error.
any ideas anyone?
please help
how can you connect your ipo d to the computer by wi-fi??
the thing is, it doesn't have internet. so how do you do it??
The Remote works well on my mac! but i can't upload a new skins! my mac is writing me a message like ( invalid error:-6 ) what did i done wrong? anybody as an explanation Thank's!
Sorry if I sound like a noon but, correct me if I'm wrong. You can only connect your iPad to virtual dj only if your desktop has wifi? Or can you connect the iPad on wifi to a wired desktop thru a router?
If your desktop is wired into a wireless router, and your iPad connects wirelessly to that router then it will work.
The problems I have were solved by changing my router mode from WPA + WPA2 to just WPA. I'm assuming Apple's bonjour is dodgy on a WPA2 connection?
Hey all! I've been a HUGE supporter and fan of Virtual DJ for the last 8 years or so and finally registered on this forum. We write A LOT about Virtual DJ on our music blog and just wrote up an article on getting iRemote to work with your iPhone/iPad so I'm sure it will help all of you struggling.
You can learn how to install it from the link below in 10 easy steps. Glad I can finally help and be a part of this community!
http://www.fromdjs4djs.com/virtual-dj-iremote/
-DJ David Bitton
Founder & Administrator
www.fromdjs4djs.com
Great guide ..thank you.
Bought the app which worked great on my iphone 3Gs so I bought an ipad and am very disappointed. On the ipad the app is very glitchy and pauses a lot. The sliders are not reliably responsive and you can use only one control at a time. VDJ7.0.2 has also been freezing up while using the ipad app. with both a PC running Vista and laptop running Win7.
This app is so glitchy on ipad that you can not use it in a real live situation. Is anyone else having this problem on ipad? I have the 16gig wifi. I have tried using it with ad hoc network which is even worse than a reg wifi connection using a router...even on iphone the ad hoc is bad. I get the same results when running VDj 7.0.2 on 2 seperate desktop pcs using Vista, my main Alienware laptop using Win7, and 2 other laptops using XP Pro. App is glitchy, not reliably responsive enough to trust in a club situation, and both the app and vdj 7.0.2 freeze up repeatedly.
That tells me you have a bloatware problem and you need to tweak your system, try using this software to see if it Helps you...
GameBooster: http://www.iobit.com/gamebooster.html
Good Luck,
Joey....
On my Windows 7 when I try to create an ad hoc network it says an unexpected error occured
If I have the free version will the iremote work with that???
If you have a connection problem then read all the solutions that's been posted in this thread, if you have a issue with preformance then read this thread link: https://virtualdj.com/forums/105257/PC_Version_Technical_Support/_DPC_Latency_Checker_(__2009_THESYCON)_Helped_Me_Fix_My_Audio_Problems___.html
GameBooster shuts down background services not needed to run VDJ, but you also need to be aware that your wifi and other services needed to work with iRemote so it needs to stay on, you'll have that option in the GameBoodter dialog to leave them on...
Good Luck,
Joey...
I dont know what is going on... I have repeated all the process of how to make it work like a million times and I still dont get it to work.
Steps I Did to try to make it work:
1.- Update VDJ to 7.0.2
2.- Buy the app and update it to 1.0.1
3.- Connect both the laptop and the ipod to the same wi-fi network
4.- Open VDJ
5.- Enable VDJ iRemote Checkbox
6.- Open the iRemote app on the iPod
It keeps saying Trying to locate Virtual DJ and after 30 min I check it again and it says the same!
I don't really know what to do...I've been doing this since the first day the app went out in the market and I bought it and no progress made :(
I don't really want to feel like I wasted 9.99 dollars on this app so can anybody help me? Maybe im doing something wrong, maybe my ports are blocked who knows...
I hope somebody can help me, thanks
pumpitentertainment wrote :
Works aewsome on the 3g ! Now I can sit on my counch and drink a beer , and play with my new toy
Damn you Atomix, not only am I gonna have to buy an Ipad, now I'm gonna start drinking again!!!
dj-in-norway wrote :
Works on iPod touch too yes ;)
And multi device for sure is a neat thing ;)
You can have two iPads, with one deck at each iPad etc ;)
Product Idea guys;
Virtual DJ appliance or PS3/XBox software configured to work with IPAD out of the box.. possibilities are endless!
I love the iRemote app on my iPhone4 but I wish you could shut the screen down and when you reopen it have the iRemote app still be able to connect to virtualdj. It seems that when you lock the screen to save battery it loses the connection and when you bring it back up it still won't reconnect unless you go to vdj on host computer and disable then reenablle iRemote. This makes it kind of a drag to use.
Thanks,
John
43%
