I looked through the user guide and searched the forum but I can't find anything on rewire unless I go to vdj7 home and read that it's a new feature.
Rewire and video are the features that attracted me to vdj and I would like to give them a rinse.
Can someone advise me or point me to where I can read up about it.
Thanks
Thanks
geposted Thu 16 Dec 10 @ 6:38 am
Just go to advanced config, select linein1 or linein 2 or etc, etc, next you should see the app in the 3rd drop down, click on it then just choose your input. Next make a shortcut like, "deck 3 linein 1", then start your app. In my case Reason. Reason will tell you its in slave mode. Now go hit the key you created the shortcut on and then load your track in Reason and hit play in VDJ. You should see I wave and hear that track playing. You can also look at Reason and see the track time moving. VDJ must be started first
Huey
Huey
geposted Thu 16 Dec 10 @ 7:19 am
Yes it would be nice if Atomix added info on new features (ReWire, remote app) to the PDF manual....
Atomix, have you fixed the issue with the ReWire slave device having no access to USB MIDI controllers?
geposted Thu 16 Dec 10 @ 7:40 am
Thanks for you replies :)
Huey
I was looking for the advanced config but couldn't find it until I clicked on the little button that says 'MORE' lol. Then I found the answer to most of the questions I was having.
Thanks again.
Huey
Thanks again.
geposted Thu 16 Dec 10 @ 8:17 am
I figured it.out from reading the manual, its all in there, pretty simple. I think you guys are just makin it more complicated then it really is....
Bro just like in your other thread where they told you about how to do this with the Registry yes its fixed.......
@Wyley, glad your sorted, enjoy!!
Huey
geposted Thu 16 Dec 10 @ 9:23 am
I just found it
It was in the audio setup guide, I was only reading the user guide.
You guys need to bear with me as I go though my vdj growing pains. I'm just so used to the way Traktor does things
geposted Thu 16 Dec 10 @ 3:05 pm
No worries ;)
It takes a little time to get used to and learn new things ;)
And you can ask anything here.. :)
geposted Thu 16 Dec 10 @ 4:00 pm
My comment wasnt aimed at you my friend, lol! Glad you got it all sorted out though and as DJ-IN-NORWAY says feel free to ask anything here!!
Huey
geposted Thu 16 Dec 10 @ 5:37 pm
Please don't spam the forum with the same post RyuJn, thanks.
geposted Thu 17 Mar 11 @ 2:32 pm
i tried this and i currently have two timecodes set up on channels 1,2& 3&4 . so i thought i'd put rewire (reason5) on line in 5 6 . but everytime i activate it . vdj crashes. and all i hear is a very fast stutter. everything else doesn't respond after that.
geposted Fri 01 Jul 11 @ 1:33 pm
