A quick question on effects. I just learned to map my RMX and I wanted to add more effects but can find how to map/apply to the mapping can someone give me some insight on this? I'm looking especially how to get the stutter effect!!! I tried to look in the mapper and cant seam to find it or any topics on how to achieve this function.
thanks in advance...
geposted Thu 16 Dec 10 @ 1:04 pm
if you want to use ony one effect with a button here is the script
effect 'myeffect' active
go to confing --> mappers--> select your divise-->key-learn--> "press the key you want to edit"--> action-learn --> "write down the script and place the effect name you want betwen'' in place of myeffect
geposted Thu 16 Dec 10 @ 1:27 pm
So when in mappers I hit key learn(which is the button on the Rmx that I want to use)==> then hit the action learn and type in effect "stutter' active on and then click ok. then it takes me to the screen and say's click on interface for action learn. how do I click on the interface if its not the same layout as the Rmx? which i'm trying to use the source button since I have no timecode or use for it right now.
Thanks in advance..
geposted Fri 17 Dec 10 @ 10:20 pm
Any one with Any help on this????
geposted Sat 18 Dec 10 @ 4:18 pm
The effect must actually exist in your Effects section of VirtualDJ. There is no effect called "stutter" as far as I am aware.
NOTE: VirtualDJ does not support frame cueing as found on some non-vinyl/scratch CD players.
geposted Sat 18 Dec 10 @ 5:11 pm
Thanks that answers my question. But am I doing the right sequence when I am mapping my keys like the above post or is their a different way on doing it?
geposted Sat 18 Dec 10 @ 7:45 pm
You can try Clax's Cut, or my Gates for example, if you mean stuttering on a stream.
But, if you mean CDJ's stuttering, there's no basic function to do that as far as I know. Maybe with some VDJscript you can.
geposted Sun 19 Dec 10 @ 9:21 am
For basic mapping instructions, please see: https://virtualdj.com/homepage/jpboggis/blogs/4149/VDJscript_Mapping.html
geposted Sun 19 Dec 10 @ 4:50 pm
