geposted Thu 16 Dec 10 @ 5:21 pm
Very nice, great work man. Only thing missing in other skins is a search window. Is it possible to add in yours? Thanks for all that you do.
geposted Thu 16 Dec 10 @ 8:10 pm
The request that you are asking for relating to the playlist is not possible in this version. But I'm sure it will come very shortly in a newer version of the iRemote. I will be releasing this skin are the later on this evening or tomorrow. Should be available over the weekend hopefully.
geposted Fri 17 Dec 10 @ 1:01 pm
Looks good, iremote is cool.. cant wait for your skin!
geposted Fri 17 Dec 10 @ 1:20 pm
Cool, I kind of figure it would be there if it was available. Till then, this is still really sweet! Thanks for the heads up and have a great weekend.
geposted Fri 17 Dec 10 @ 2:21 pm
Okay my iPhone skin is now finished. I have uploaded it I am just waiting for Virtual DJ to approve the skin. should be with you all soon
geposted Sat 18 Dec 10 @ 8:25 am
Okay guys my iMix skin is now available for iPhone. Hope you all enjoy using it
http://www.virtualdj.com/addons/12379/iPhone_iMix_V1_0.html
geposted Sat 18 Dec 10 @ 9:20 am
I'm the first.. Thanks.. What happen with your skin for VDJ 7... I'm waiting this....
geposted Sat 18 Dec 10 @ 9:29 am
Look here
http://www.virtualdj.com/forums/138740/Virtual_DJ_Skins/Mix_Lab_skin_for_4_decks_.html
geposted Sat 18 Dec 10 @ 9:46 am
Thanks man, so many VDJ Christmas presents this year! Thanks for all the hard work.
geposted Sat 18 Dec 10 @ 11:06 am
I have updated the skin V1.1 to add these new features. To access these new features at the bottom of the deck screen there is a pitch button. press to access new deck
Updated 20/12/2010
iMix V1.1
Deck Pannel Deck 1 2 3 4
Add Pitch Slider.
Add Pitch Reset.
Add Pitch Lock.
Add Key Lock.
Browse Pannel
Add To PlayList Button.
Updated 20/12/2010
iMix V1.1
Add Pitch Slider.
Add Pitch Reset.
Add Pitch Lock.
Add Key Lock.
Browse Pannel
geposted Mon 20 Dec 10 @ 2:41 pm
Good.. Goog add...
geposted Mon 20 Dec 10 @ 4:58 pm
Download section is only showing source files not installers
geposted Mon 20 Dec 10 @ 6:35 pm
Matt, wonderful skin. Great and detailed graphics. Well done, 5stars from me.
Just download the zip file (source) and place it in to the VirtualDJ/Skins/iPhone Folder. If this doesnt excist, just create it.
geposted Mon 20 Dec 10 @ 7:01 pm
Matt can you take a look at a few things..
1. Mixer-Volumes. The button level 0% lights reversed. I mean when volume=0% should be on instead of off.
2. Browser. The small PLAY indicators do not light up when deck is playing, or i miss something here?
3. Pitchbends should the opposite Bend minus should make the deck go slower
4. I suggest the pitch reset instead of pitch 100%. It makes the pitch smoothly go to zero.
Thanks
Thanks
geposted Mon 20 Dec 10 @ 7:21 pm
iMix Black comeing Soon
geposted Mon 20 Dec 10 @ 7:25 pm
Very goog this color... It's excellent to work at night..
geposted Tue 21 Dec 10 @ 11:30 am
Love the screen shots, but I am having an issue viewing decks. I can see the browser and mixer fine. But I just get a white screen with very little info when I try to use a deck.
Specs:
iPhone gen 2 - IOS 3.13
Running iRemote 1.0 (then updated to 1.01 today, still same issue)
IMIX 1.0 (this skin) and now the new 1.1 and still same issue
This is what I see when I try to view a deck:
Any ideas?
Specs:
Any ideas?
geposted Tue 21 Dec 10 @ 5:08 pm
Did you try to update the IOS ? Is 3.13 the latest you can instal ?
geposted Tue 21 Dec 10 @ 5:24 pm
Ufortunatley , yes, that is the latest available for me. I can't even buy an update like the iPod touch guys. Usually a big fan of testing and staying current otherwise.
Final word, Gen 2 iPhone is not supported in IOS 4.X. Looked at a bunch of pages (after update telling me that 3.13 was the latest) and found a support page that says iPhones 3G, 3Gs and 4g are all that it supports.
geposted Tue 21 Dec 10 @ 5:26 pm
