its happened several times since v6.
and right now im on a clean install of Win7
aero desktop disabled..
geposted Thu 16 Dec 10 @ 7:01 pm
That looks to me a graphics card problem or your display is not set correctly. try this right click on desktop and choose personalize, then choose display at the bottom then choose change display settings. Do you see your graohics card listed there? If you do select the resolution to recommended. Give that a try
geposted Fri 17 Dec 10 @ 3:58 am
Either that or low memory
geposted Fri 17 Dec 10 @ 7:50 pm
i got the latest nvidia graphics drivres, dont have video output issues.
this happens randomly when i minimise virtualdj too often.
though the time before when this happened, virtualdj had a ghost of itself on screen and was only updating parts of the screen.
(browsing was not updating, play buttons werent visible but i click in their general area on screen, they still work.)
as u can just about tell, im using the default skins, and not tampered with them.
** Low memory 'Could' be a possibility, but adding more ram chips would mean having to get a whole new PC, so not a quick fix.
geposted Tue 21 Dec 10 @ 3:58 pm
