today i wanted to map my S4 to vdj. So far i have the channel faders, eq's ,crossfader, headphone mix, channel gains, play button, jog wheels (sort of they pitch bend now)
when i try to map the pitch sliders like :deck 1 pitch and deck 2 pitch they both operate at the same time.
i cannot map the cue button or the loop in or out.
if i am correct you have to tell vdj there is a shift button and you have to map it first for it to work. then i can use shift to delete cue points
thanks
thanks
geposted Thu 16 Dec 10 @ 8:34 pm
