pls do help with some mapping commands. I want to modify some buttons on my hercules mp3 e2 controller.
First i need hot cues:i want when the sratch button is active then it can turn the 4 buttons into hot cue 1 2 3 4 and Holding the scratch button can help me select the hot cues and also delect them.
Second I need the effects to have a controller.So like have the pitch as my effects controller.eg so that i can use the filter as it used normally.(wet and dry)
Third I need my Loops to also have a controller.the pitch knob will be perfect
Fourth.I need Sampler:when the automix button is active i want it to turn the four buttons into four sample button with the pitch slider as volume control.
i am using the trail version of virtual dj 7
I hope someone helps
geposted Sat 18 Dec 10 @ 1:50 am
