Hi,
I have a Logitech USB mic (Yea, looking to get a real mic hopefully in the future) I use; everything configuration-wise works great, but the mic wanes between working properly and changing to awful static and voice echoing. My mic works great with Audacity and all other programs; just not VDJ.
I work from an m8100n HP desktop.
Any help would be appreciated, thanks!
geposted Sun 19 Dec 10 @ 12:57 pm
Can you post a screen shot of your configuration settings in VDJ, please?
geposted Sun 19 Dec 10 @ 12:59 pm
http://img691.imageshack.us/img691/8905/configns.jpg
The mic is plugged into the back of my computer.
geposted Tue 21 Dec 10 @ 5:07 am
Well, I got a new mic (Audio-Technica AT2020), and the same problem is going down; config settings are pretty much the same.
geposted Sat 25 Dec 10 @ 11:36 pm
Hi
Yes, same problem for me also running VD 7.0.2, with ALESIS USB Pod caster mic, I am getting the same problem, I have uploaded a mp3 for you to listen to
http://cid-5fbc91d67ee74fa7.skydrive.live.com/redir.aspx?resid=5FBC91D67EE74FA7!203&authkey=4Eyxq5OWKlI%24
geposted Tue 28 Dec 10 @ 3:50 pm
