I have recorded mixes using 6.0 but can't locate them in VDJ files to replay them. How can I fine them?
geposted Sun 19 Dec 10 @ 5:40 pm
Hi When you click on record you would have clicked the config button in there you would choose MP3 Or Wav where it says file there is a button to the right which you would select and ask it where you would want to save your files. I'm not sure if this applies to version 6.0 as I'm using pro 7. Good luck
geposted Mon 20 Dec 10 @ 4:35 am
