Hi everyone,
I'm using Virtual DJ's free version for Mac to play some music at a party. As it's my first time DJing I'd like to have a fairly set playlist that I can alter on the fly.
I'm confused about how to set up my playlist. If I build my set ahead of time in the playlist space on the right, and I drag the songs into the decks, it's then removed from the playlist. So I'm not sure how I could save this playlist and use it for the night of the party. I guess I could just build my track listing in iTunes but there must be a better way to do this.
I'm also confused about how to preview tracks without dragging the song into the decks. I read elsewhere on the forums that you can right click the song in the browser to preview, but I don't see that option with my free version when I right click.
Any suggestions would be appreciated. Thanks
geposted Sun 19 Dec 10 @ 6:41 pm
hey buddy if you play the playlist before you go to your gig like every song you have preperd what you can do is. after playing all the songs vdj will save this then
go into your history and click on the date you played it and it will pop up on the right hand side of the screen.. and you can just click the little green button and it will play it in auto mode .. it works in pro not really sure about home???
hope this helps
hope this helps
geposted Mon 20 Dec 10 @ 3:28 am
That's helpful. Thanks DJ Gibbsy!
geposted Tue 21 Dec 10 @ 6:44 pm
