I have finally installed version 7 once the video load time was fixed. I noticed that on my Stealth controller the pause and cue buttons do nothing now.
Is there something I should script? Version 6 worked fine and was plug and play.
Thanks for any help.
geposted Sun 19 Dec 10 @ 11:26 pm
Try resetting it back to the factory default mappings.
Go to CONFIG -> Mappers, choose the StealthControl in the drop-down list and click the reset to factory settings button at the bottom-left of the Mappers dialogue box.
geposted Mon 20 Dec 10 @ 4:55 am
I will try it. Thank you.
geposted Mon 20 Dec 10 @ 6:50 am
Solved. Thank you.
geposted Mon 20 Dec 10 @ 5:23 pm
