Hi,
I recently bought the new Hercules 4-MX and it comes with Virtual DJ 7 LE.
Ive downloaded 7.0.2 and have upgraded to the trail "Pro" version before i buy in full.
When i go to config and try to change the skin, nothing happens?
I select the skin i want and click ok, but the 4-mx, 4 deck skin simply stays there.
Anybody got any ideas?
I would like to change to the VDJ7 Skin for 2 decks only if possible.
Appreciate your help
Simon.
Simon.
geposted Mon 20 Dec 10 @ 4:42 am
Theres probably not a lot of people with that controller yet. Be keen to hear what you think of it.
geposted Mon 20 Dec 10 @ 5:19 am
So far so good!
Seems will worth the money. Well built, well designed and looks good, not cheap.
Early days!
Early days!
geposted Mon 20 Dec 10 @ 10:47 am
Anybody have any ideas on the skins issue and as to why i cant get them to change?
S.
S.
geposted Tue 21 Dec 10 @ 3:41 am
My guess is skins are only for pro version?
geposted Tue 21 Dec 10 @ 4:26 am
Ive got a traial Pro version for 20 days which i got with LE.
It should have all the features active.
Cheers
S.
Cheers
S.
geposted Tue 21 Dec 10 @ 5:06 am
