hi
I'm trying to change the rhythm wave on the vdj default 1280x800 2 deck skin to this one
I'm not sure what I've got to change the code to
<rhythm pannel="Rhythm">
to give me that wave form
have looked at the 4 deck xml but its script is totally different and cant for life of me work out what parts of it i need
thanks
thanks
geposted Mon 20 Dec 10 @ 12:36 pm
You Need to use the new "rhythmzone" in your skin to use this.
If you search my blacksheep skin for "mirrored" - that will give you the code.
geposted Mon 20 Dec 10 @ 1:02 pm
cheers Dan i will take a look at it
geposted Mon 20 Dec 10 @ 5:36 pm
