Hi, I'm new to VDJ7, been using vers.3.4 for years. I need help with VDJScript. My current setup is 4x Xone:1D's and a DDM4OOO. I want to assign 1 button on the 1D to toggle between skin pannels deck 1a, deck 1b & deck 1c. No need for LED comands as no lights on the 1D. Many Thanks
geposted Mon 20 Dec 10 @ 2:40 pm
So you need 1 button to each Xone1D ?..
This will work for deck 1
skin_panel 'deck1a' on ? skin_panel 'deck1b' on : skin_panel 'deck1b' on ? skin_panel 'deck1c' on : skin_panel 'deck1a' on
for deck 2
skin_panel 'deck2a' on ? skin_panel 'deck2b' on : skin_panel 'deck2b' on ? skin_panel 'deck2c' on : skin_panel 'deck2a' on
for deck 3
skin_panel 'deck3a' on ? skin_panel 'deck3b' on : skin_panel 'deck3b' on ? skin_panel 'deck3c' on : skin_panel 'deck3a' on
for deck 4
skin_panel 'deck4a' on ? skin_panel 'deck4b' on : skin_panel 'deck4b' on ? skin_panel 'deck4c' on : skin_panel 'deck4a' on
for deck 2
for deck 3
for deck 4
geposted Mon 20 Dec 10 @ 8:21 pm
Ahh!!! I see the logic to that command, which has helped me to understand this new language a little better too. Thanks very much djdad
geposted Mon 20 Dec 10 @ 9:23 pm
