So, I cue up a track to the beginning of a video, hit cue. It puts the cue point on. If I unload it and reload it, the cue point is still where I placed it. Yet, next night, the cue point has moved right to the beginning of the video file. This is was happening on 7.01 and still on 7.02
I t's not happening on every track, just selected ones. Is this happening to anyone else or I'm I going mad with festive work stress!!!!!!!
geposted Mon 20 Dec 10 @ 10:46 pm
Same problem ! But not with all my tracks. Very strange. Why some cues stay in the right place and others move ?
geposted Tue 21 Dec 10 @ 1:30 pm
I was having this same problem, and I think I figured out what causes it:
typically i begin playing a track from the first cue point I've set. I also usually mix out of a track before it is entirely over, if even just a couple measures before the track end. so a lot of the time I'm stopping a track and switching it out before playback has entirely finished - because I have the decks protected, by habit I hit "cue" when i'm done (otherwise dragging a new track onto the deck will bring up the "music is still playing, are you sure?" error (or however it's worded - i didn't go look).
However, when a track plays fully to the end, virtual DJ stops it and rewinds it to the absolute beginning (instead of the first cue point i used). if the track stops on its own, and I still hit "cue" out of habit - since playback is stoped, virtualdj will "set" the most recent cue point used.
it would be nice if there's a way to make virtualdj rewind a track to the last cue point used after it has finished playing
does this explain your problem?
geposted Wed 09 Mar 11 @ 6:37 pm
