Hello, I've recently installed VDJ7 on my MacBook pro and I am noticing that the lips are not moving with the video. The first night I didn't notice any issues like this, just yesterday I was playing around and every video has this problem. I have played the videos in a regular video player and everything is fine. Is anyone else having this issue? and is there a way to fix it? Thank you.
geposted Tue 21 Dec 10 @ 12:43 pm
what's the sample rate of the audio of those videos? 44.1 Khz or 48 khz?
geposted Tue 21 Dec 10 @ 4:41 pm
Sorry it took me so long to respond, its been crazy for me. The videos that are out of sync are 44k AAC. Do you know if there is anything I can do? Thanks again, I will respond quicker next time.
geposted Tue 18 Jan 11 @ 3:40 pm
I use this information in another Thread; Far as videos go, how are your videos formatted what's there FPS ??? (frames per second) what's there resolution ??? I think Serato put it best on there FAQ : http://serato.com/search?js=1&q=Video+FAQ&go.x=0&go.y=0 bump your videos again that information and let me know if it doesn't help ??? i.e. I have all my video formatted like this: 25 FPS, 1280x720 Resolution, not to exceed 40-60 mbs per video 3-5 mins long and one thing if you have all you media on external Hard drive double check on the rpm (I'd recommend 7200 rpm or better) and if you're using a USB cable to transfer the data I would recommend using a fire cable or better depending on your computer system. My Macbook pro has a Firewire 800 cable and my PC uses a eSATA cable.
thanks for the post,
Maximus Moretta
Maximus Moretta
geposted Mon 24 Jan 11 @ 7:07 am
i am having the same thing my video is not in sync but it was a month ago when i dj last WTF happen
geposted Thu 13 Oct 11 @ 4:30 am
