I am currently using the trial version of Virtual DJ. Seeing if the MIDI function will work with Virtual DJ, however, i'm having some trouble. I have an Logilink MIDI adapter as an audio interface (http://www.amazon.co.uk/LogiLink-USB-Midi-Out-adapter/dp/B000XRI3CC), but Virtual DJ does not respond to it. I've tried going on the 'mappers' section and manually configuring it, but have had no luck. Does anyone have any ideas on how to work it? I would like to use the crossfader from the mixer through Virtual DJ
geposted Tue 21 Dec 10 @ 1:46 pm
I use http://www.amazon.co.uk/ESI-MIDIMATE-II/dp/B000WA8Q18/ref=sr_1_1?ie=UTF8&qid=1293109983&sr=8-1-catcorr with Mac/Win and DJM-800. It was configured as «Generic MIDI mapping». Did you activate midi at mixer by pressing button "MIDI Start/Stop"?
geposted Thu 23 Dec 10 @ 7:16 am
Thanks for the response.
The BPM on my mixer works and recognises the BPM from Virtual DJ so I think it's something i'm not doing right on Virtual DJ. I've used the simple MIDI wrapper, however, when I move a knob or slider on my mixer to teach a command nothing appears to happen, i'm not sure if i'm configuring it right?
geposted Sat 25 Dec 10 @ 9:09 am
