Topic: Mapping the Numark Mixtrack?
Hey guys, I jsut purchased the Numark Mixtrack, where/how can i get the mapping for VDJ and my unit please? Oh, forgot, I have version 6.
geposted Tue 21 Dec 10 @ 6:45 pm
It is native in vdj7. Upgrade to vdj7 and it will just work when you plug it in.
Thanks, can you tell me what the procedure is to do the upgrading please?
Thanks, tell me please, on how many machines can I have VDJ at the same time, I am being told "2", like on my laptop and my desktop, is this correct please?
The End User License Agreement (EULA) allows you to have the software installed on up to two computers at any one time, providing that they are both for your own personal use and will not be used simultaneously (E.g: Second installation as a backup or for practising at home is OK, allowing a friend or another DJ to use it is NOT allowed.)
You may also uninstall the software from an old computer and then install it onto a new computer.
NOTE: If you intend to sell, give away or dispose of an old computer, you must remove VirtualDJ from it first.
Once purchased and registered, you can download the install file for the software again (If needed) from the Download Center: https://virtualdj.com/download/updates.html
