Hi,
I'm testing out VirtualDJ and trying to see if I can create device/mapper files so that I can control "LED"s on TouchOSC on my iPad (i.e. VU meters, etc. through its display).
Currently I've got this (all very basic so far...don't want to jump in without making a few buttons/LEDs work first):
<?xml version="1.0" encoding="UTF-8"?>
<device name="IPAD" author="Schuyler" type="MIDI" decks="2">
<button note="1" name="PLAY" deck="2" />
<button note="2" name="STOP" deck="2" />
<button note="4" name="SYNC" deck="2" />
<button note="3" name="CUE" deck="2" />
<slider cc="0" name="PITCH" deck="2" />
<led cc="1" name="LED_VUOUT" channel="1" />
</device>
<mapper device="IPAD" author="Schuyler" description="iPad" version="700" date="21/12/2010" priority="10">
<map value="PLAY" action="play_button">
<map value="STOP" action="stop_button">
<map value="SYNC" action="sync_button">
<map value="CUE" action="cue_button">
<map value="PITCH" action="pitch">
<map value="LED_VUOUT" action="get vu_meter">
</mapper>
I'm sure there's issues in the implementation but I can't even test it yet...the device doesn't show up in VDJ 7! There is intentionally no sysex since an iPad doesn't use it...
All files are placed in the proper directories with *.xml extensions.
Any suggestions?
</device>
</mapper>
Any suggestions?
geposted Tue 21 Dec 10 @ 9:42 pm
