Topic: Adding more speakers to Hercules MK4
Ive got the hercules mk4 with the built in soundcard and basically i just brought another set of speakers (current ones are 400watts rms) i brought some more at 300watts rms..
id have to daisy chain the wires up as theres only one rca output from the midi console itself. but basically there would be a tremendous amount of power running around the speakers itself...including the peak wattage will my midi console blow up lol?
theres a ground on the midi console itself ? is there need for that...theres no infomation on the max is can output because its not an amp at all but im still unsure ....
thanks
geposted Tue 21 Dec 10 @ 10:28 pm
Hello Premal,
As DJ Console Mk4 is powered by the USB, its ground is the ground of the USB power, so the ground lays either in the computer (if Hercules DJ Console Mk4 is connected directly to the USB port in a computer) or in the power supply of the USB hib, if you use a USB hub with a power adapter.
The risk your speakers wattage has an impact on the console is limited, but if you are afraid of it, you can connect a direct injection box with a ground lift between your Hercules Mk4 audio output and your speakers.
cheers bud
