Just got my unit. i installed the asio drivers from cd, using virtual 7.0.2 and when i turn on virtual dj it says "Cant Start Program Missing D3DX9_36.DLL from computer. try reinstalling program to fix this problem."
which i did and i still get it. i was using the denon 4500 before and no problems.
can anyone help?
my system is windows 7 pro 64bit, 8gb rams, quad core, 1gb ati 5870 ddr5, 7200rpm 64mb cache hardrive.
can anyone help?
geposted Wed 22 Dec 10 @ 6:11 pm
First, search your PC to check if the DLL is on your system somewhere...
On mine it's in C:\Windows\system32
If it's not anywhere on your system, you should easily be able to find somewhere to download it from.
It's a Microsoft DirectX file, so another option is for you to download and install DirectX again, from MS (Google for dxwebsetup).
geposted Thu 23 Dec 10 @ 8:23 am
Download and install Microsoft DirectX 9c from the following location:
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
geposted Thu 23 Dec 10 @ 4:45 pm
Just hooked up MC6000...Cannot cue music using the CUE buttons.
Have to turn up slider and move Cue Pan towards master to hear anything.
Any ideas>
Also, what are the correct settings in the SOUND SETUP Menu?
IINPUT ...?
OUTPUT?...
SOUND CARD? (Sometimes the Sound Card Drop down menu shows DENONMC600 / other times
it shows DENON DJ ASIO DRIVER...I get sound with both settings?
Any ideas>
IINPUT ...?
OUTPUT?...
geposted Mon 23 May 11 @ 12:31 am
