Hi guys I have been working for over an hour on this and I am just not getting it. I am trying to set up on a single timecode set up with a sl1 box. When I do the easy config i have no problem however I can not record my mixes as I am using an external mixer. So what is my set up in advance config so I can do single timecode with an external mixer and be able to record with my line in running out of my mixer?? I have read the guides and I just cant seem to get a timecode signal in advance config.
Thanks
Thanks
geposted Wed 22 Dec 10 @ 7:55 pm
Thanks
Just as an alternative, have you tried staying with simple setup and running the line in to your machine while recording with another program such as Audacity (which is free)?
Thanks
geposted Thu 23 Dec 10 @ 12:44 am
I can use an external program to record my mix but I also need this feature to work to record my video mixes as well
geposted Thu 23 Dec 10 @ 7:51 am
