can anyone help me here?
I cant for the life of me get my itunes folder to show up where the other folders are on the left side of the screen.
If anyone can point out what im doing wrong or give me some advise, it would be greatly appreciated.
Thanks for any comments or suggestions.
geposted Thu 23 Dec 10 @ 11:05 pm
Go into "Config/Settings" and then click on the "Browser" tab, over to the left youll see a row of folder types (i think thats what youd call it) make sure "Show ITUNES" is checked.
Hope that helps
Huey
Hope that helps
Huey
geposted Thu 23 Dec 10 @ 11:12 pm
iTunes icon missing from VDJ browser (unable to view iTunes playlists as a consequence).
I also can’t get my iTunes icon/folder to show up where the other folders are on the left side of the screen.
Have made sure in \"Config/Settings\" and then click on the \"Browser\" tab, \"Show ITUNES\" is checked.
I’m using iTunes 10.1.2 (recently installed after laptop crash) and Virtual DJ 7 (recently upgraded) / laptop running Windows XP.
Was working fine before with VDJ 6 and 5
Any help greatly appreciated.
geposted Tue 08 Feb 11 @ 5:51 am
Have you ever let VDJ scan your HD? If VDJ doesn't know the iTunes-folder is there it won't find it on its own.
Right-click on the driveletter in the browser where the iTunes-folder is stored and choose "Add to search Database".
Let us know if this helps.
geposted Tue 08 Feb 11 @ 1:37 pm
gosh i'm facing the same problem as well. i can't find my itunes playlist in the browser. Same thing, checked the "itunes" box in settings. Tried adding my HD to database. still no go.
Anybody knows how to solve this?
geposted Sat 12 Mar 11 @ 4:09 pm
Can anyone Help? I am using The VDJ 7.0.3 Pro Pc version The only Itunes Video That VDJ Reads on my Pc are The itunes Video That i Personally Loaded into itunes. However The Video That I purchased from itunes VDJ will Not Read, Does VDJ Read Purchased Itunes Video?
geposted Sun 03 Apr 11 @ 8:29 am
Itunes uses full DRM for all its music and video, the media has to be athorized by Itunes to play on that computer or device.
I have no problems in VJ7 but all my Itunes stuff was puchased with that machine.
geposted Sun 03 Apr 11 @ 9:28 pm
iTunes doesn't use DRM for its music any more. However, all the videos on the iTunes store are still heavily DRM'd...
geposted Wed 13 Apr 11 @ 1:25 am
Try this:
CONFIG---INFO---RESET TO FACTORY SETTINGS
Good Luck...
Try this:
Good Luck...
geposted Mon 18 Apr 11 @ 6:20 pm
Sweeet! Resetting factory setting works fine!
geposted Tue 02 Aug 11 @ 3:12 pm
